ford escort valves
Flightdeck on Wed December 10, 2008 2:13 PM User is offline
My escort low and high side valves look like the have a rubber ball in them instead of a standard type valve.Can these be replaced ?If so I see the aluminum fitting on the low side piping has hex shape like a wrench could remove them.Could I unscrew these and replace with astyle like my GM with the tire valve fitting?
JACK ADAMS on Wed December 10, 2008 3:44 PM User is offline
Here are two links for what you will need to change the Hi side valve core and the Low side valve cores. You will have to use these types as a tire valve core will not work.
Edited: Wed December 10, 2008 at 4:28 PM by JACK ADAMS
Flightdeck on Wed December 10, 2008 4:17 PM User is offline
Thanks for the help!!!!
JACK ADAMS on Wed December 10, 2008 4:30 PM User is offline
Try the links now. Had to fix them with out having an error.
