Round fitting with spring...help
89chargedbird on Thu December 04, 2008 9:00 AM User is offline
Year: 1993
Make: Dodge
Model: D-250
Engine Size: 5.9L Die
Refrigerant Type: R-12
Ambient Temp: 62
Hey all,
I have a 1993 Dodge D-250 Diesel Truck and I am need to replace a hose between the accumulator and the condenser. The fitting at the condenser is round and has a spring inside of it. How do I remove it?
Any information will be greatly appreciated.
Brad
GM Tech on Thu December 04, 2008 9:37 AM User is offline
Go to your favorite parts house- or order on-line here- and get the spring-lock connector - disconnect tool- basically and expander for the garter spring- - they may them in plastic and good ones are metal...
TRB on Thu December 04, 2008 10:01 AM User is offlineView users profile
Spring Lock Release Tool
89chargedbird on Thu December 04, 2008 10:08 AM User is offline
GM Tech,
I will order part from here because I am going to order some other stuff, the only tool that I could find was here; https://www.ackits.com/pc/41-02182/Miscellaneous/41-02182+-+Toyota+Spring+Lock+Release+Tool,
This is for toyota and I don't think this is the right tool.
Would you please send me the link for the correct tool to order.
Thanks and have a wonderful day
Brad
89chargedbird on Thu December 04, 2008 10:10 AM User is offline
TRB,
Dang your fast, as I was inputting my reply you posted exactly what I needed.
Brad
TRB on Thu December 04, 2008 10:14 AM User is offlineView users profile
Here is a Toyota Spring Lock tool.
41-02182
PS: Thanks for the support.
Edited: Thu December 04, 2008 at 10:14 AM by TRB
mk378 on Fri December 05, 2008 10:29 AM User is offline
On the old Dodge you should need the American standard type, usually called a Ford springlock tool because Ford originated these lousy connectors. AMA and most places that sell car tools will have them, much more common than the Toyota.
