How to prepare my A6 for installation
Robert57 on Wed December 03, 2008 7:54 PM User is offline
Year: 1972
Make: Chevy
Model: K-10
Engine Size: 350
Refrigerant Type: R12
I'm keeping my A/C unit operating on R12. Before I install the compressor how do I proceed with amineral oil flush so it has the best chance for survival.
Do I just stand it on end to let the old oil out? Put new oil in..rinse and repeat? Seeings how the drain plug is offset, I wont get all the oil out of it that way.
Furthermore, when I fill it up with the new oil, do I pre-measure the amount ( I believe it is 10 oz) and put it in the back? Sorry if this is too basic I'm learning as I go.
TRB on Wed December 03, 2008 8:19 PM User is offlineView users profile
Turning the hub of the compressor will help pump some oil out. Use the drain port and the suction & discharge ports including letting it sit ports down. The more times you use fresh oil the better chance you have on removing the oil oil. Drain it flush it twice with intended oil and then fill to capacity is what I would suggest.
Cussboy on Wed December 03, 2008 8:49 PM User is offline
I pretty much did what TRB states above when I replaced my '88 Mazda B2200 compressor in 2003. That rebuilt compressor (Air Pro from AMA, by the way) came filled with an ester-type oil (I confirmed that at work in a minute with our FTIR spectrophotometer) and I used mineral oil to flush it a few times, draining and refilling each time. Then I added correct amount and re-installed, then pulled vacuum and added R-12.
TRB on Wed December 03, 2008 8:54 PM User is offlineView users profile
Thanks for the support Is it still working?
As for the OP, maybe some more data on the failure and what is being done besides just an oil change.
Robert57 on Wed December 03, 2008 8:55 PM User is offline
So how do I know it's at capacity. Do I just pre-measure it ?
TRB on Wed December 03, 2008 10:26 PM User is offlineView users profile
11 ounces for the A6, with single evap.
