More Jetta AC Probs
Performance Kote on Thu September 18, 2008 7:18 PM User is offline
Year: 2001
Make: VW
Model: Jetta TDI
Engine Size: 1.9
Refrigerant Type: R134
Ambient Temp: 88
Pressure Low: 30
Pressure High: 210
Well, I replaced my compressor , expansion valve , and drier , vacked it down and charged with the called for amount of R134 and am getting 40 degree vent temps , however my compressor intermitently kicks off and temps come up for a few minutes until it kicks back on . I can sometimes get it to come on sooner by hitting the ac switch a couple of times . I pulled the connections to the Fan Control Module and everything looked good . Any ideas ? Also Vag Com showed no codes .
tony1963 on Sun September 21, 2008 2:10 PM User is offline
I would have replaced all of the pressure sensor/switches at the same time. On newer vehicles, I replace those, too. A fault sensor in the high side will do that.
Grove Automotive Group, Inc.
An Alabama Corporation
TRB on Sun September 21, 2008 4:46 PM User is offlineView users profile
With a variable displacement compressor I would be more concerned with proper charge level. Control valve has lead to more trouble than pressure switches. IS this a new Sanden compressor or another replacement brand?
Performance Kote on Wed September 24, 2008 6:52 PM User is offline
Well , I ran the car with gauges on it while driving down the road and once moving and over 2500 rpm my high pressure drops to 100psi and the low pressure stays 25-30 psi . A buddy of mine related that it sounds like the condenser may be plugged . The temp on the inlet is too hot to touch and the outlet is slightly above room temp . Whatayathink ? I cant recall the brand , however I dont think it was a Sanden
Edited: Wed September 24, 2008 at 6:53 PM by Performance Kote
