how can I increase my AC
Mike8623 on Sat September 13, 2008 4:48 PM User is offline
I was wanting to increase the amount of cold air coming into my pickup truck. I was wondering if you used a higher rpm blower motor to blow faster across the coil if it would increase the amount of cold air. If not could use a larger compressor, etc. to enlarge the system.........
GM Tech on Sat September 13, 2008 8:14 PM User is offline
are you certain the system is up to OEM specs now?? like charge level, clutch fan, pressures and temps may be nice- as well as type of vehicle...
Chick on Sun September 14, 2008 6:39 AM User is offlineView users profile
Just to add, remember that on lower fan speeds the air is always colder since it hangs out over the cold coils longer. I fan blowing faster will not be as cold, since it spends less time on the cold coils. As GM tech stated, a lot more information is needed, and we may be able to help you. Could be your evaporator isn't getting cold..Or a lot of other scenarios that we can only guess at now...
Hope this helps
