Nippondenso 10cyl Clutch Removal
69Sixpackbee on Mon September 08, 2008 4:03 PM User is offline
Year: 1990
Make: Toyota
Model: Pickup
Hey, all,
I need to change the clutch coil in my 1990 Toy pickup. When it gets warm after a while of operation it blows the 10A "A/C" fuse. But when I first start up the system and use it on short trips it operates just fine. I believe that the potting of the coil is broken down and the windings are starting to short when it is heated up.
Is this something I can do on the truck? Do I need a puller or can I use a bolt that is coned on the end to remove the plate and then just remove the snap ring?
It looks pretty accessable once I remove the radiator, fan, etc...
Thanx,
Bud
Chick on Mon September 08, 2008 10:26 PM User is offlineView users profile
Just remove the 10mm bolt, the clutch plate slides off, remove the snap ring to get the pulley off and the coil is exposed. I believe the coil on those is held with a snap ring also..Hope this helps..
iceman2555 on Tue September 09, 2008 9:58 AM User is offlineView users profile
The coil retainer/snap ring has a index factor. Notice that the snap ring is beveled on one side, this bevel should face toward you. Failure to install properly may result in clutch damage.
69Sixpackbee on Tue September 09, 2008 10:50 AM User is offline
Great!
Thanx, guys!
