Replacing Evaparator
abtanner on Fri September 05, 2008 4:55 PM User is offlineView users profile
Year: 1992
Make: Chevy
Model: 1/2 Ton, P.U,Z71,4X4
Engine Size: 350cu
Refrigerant Type: R134
I must replace the evaperator, does anyone have an writen procedure for this task that they would share? I would be most greatful.
TIA,Al.
TRB on Fri September 05, 2008 7:36 PM User is offlineView users profile
Process will be similar to what is listed in our aftermarket a/c installation instructions.
14378
Or you can buy the AllData Subscription..
mk378 on Fri September 05, 2008 7:52 PM User is offline
The AMA instructions are actually much better detailed than alldata, as well as free. But in a nutshell you'll remove the heater A/C case from the truck (requires taking a bunch of other stuff off first), crack it open from the bottom, and R&R evaporator core.
abtanner on Sat September 06, 2008 2:20 AM User is offlineView users profile
MK378;
Thanks for ya timely responce. The AMA procedure seems straight forward and 'do-able'. However,in ref. to page three ,step number 19, (drill two 1,1/2"holes into the
firewall).Why is this mod. needed? Likewise, in steps 24 and 25, why is "micro sw."installation and rewire of the "press.cycling sw."needed. I wish to keep the A/C sys. in it's standard configuaration.
Thanks again for ya input, I'm most greatful. TIA for ya reply. Al
TRB on Sat September 06, 2008 2:42 AM User is offlineView users profile
Dude, those instructions are for installing our (AMA) after market system. The procedure to remove the case assembly is what is need to R & R the OEM evap core. So pick the parts that help with your repair and forget the rest!
