air in system?
mak11 on Fri September 05, 2008 12:56 PM User is offline
If an ac system has not been properly vacuumed. how will it affect the high and low pressure readings?
HECAT on Fri September 05, 2008 1:50 PM User is offline
Air is a non condensable gas, excessive high pressures, no heat removal, no cooling.
HECAT: You support the Forum when you consider for your a/c parts.
GM Tech on Fri September 05, 2008 2:52 PM User is offline
I've done those studies on a V-5 system (variable sroke pump) with small amounts of air it will artificially raise the suction pressure enough to cause evap freeze-up because pump does not destroke at correct pressure- with no vacuum pulled it will cause high pressure cut-outs and no cooling.
Chick on Fri September 05, 2008 9:08 PM User is offlineView users profile
Also damage to the compressor....
mak11 on Sat September 06, 2008 4:57 PM User is offline
Thank you very much for your replies.
