compressor fitting leak
max on Sat August 30, 2008 1:52 PM User is offline
Year: 1994
Make: Buick
Model: Lesabre
Engine Size: 3.8
Refrigerant Type: r134a
Ambient Temp: 70
I'm having trouble with a leak where the refrigerant lines attach to the compressor. I lubed the gaskets with a bit of ester oil and tightened the bolt firmly. What is the correct way to install these 2 gaskets? Should they be assembled dry? Do I need nylog? How tight should I go on the fitting? Thanks for any help this is driving me crazy.
TRB on Sat August 30, 2008 2:58 PM User is offlineView users profile
Nylog is nice but its not the reason for the leak. Make sure you have the correct o-rings and the the manifold hose set is seating correctly.
max on Sat August 30, 2008 4:54 PM User is offline
Do you have any tips to ensure the manifold is seated correctly? I know I'm doing something wrong. Is the ester oil ok to lube the seal or should I install the seals dry? Thanks
GM Tech on Sat August 30, 2008 5:01 PM User is offline
Your compressor uses sealing washers- they go in dry- no lube is needed- that is what makes them so nice-if you have a leak, you may not have the right sealing washers for your applications- you should have a step block manifold on a step-block compressor- that uses two sealing washers of equal thickness. If for some reason you have a salvage yard pump on there, prior to '94 MY then you would have a non-step block compressor that doesn't match your step-block hose...and that would create a bad seal situation and your leak.
max on Sat August 30, 2008 8:49 PM User is offline
The compressor is a rebuilt unit but it is the same as the one I took out. I put ester oil on the seals - this has to be why it's leaking. I ordered a new set of seals and will try again. On the compressor that came out one refrigerant port is slightly more recessed than the other. Is this how you can tell if it's the step block design. Thank you very much.
Chick on Sat August 30, 2008 9:10 PM User is offlineView users profile
As GM Tech stated, the step design is actually, one port is deeper than the other..If your original was straight across with no recess, you need a compressor either the same, or one thin and one thick sealing washer.. Hope this explains it for you..
max on Sun August 31, 2008 6:37 PM User is offline
All I can say is a sincere thank you for solving a mystery that has been bugging me for most of the summer. I really thought it was me doing something wrong. Anyway what I have is this- the original manifold and compressor is the step design - the rebuilt compressor is the straight across design. I swapped some parts with a buddy and got the compressor so it would be good if I can get this one to work. Can I order the correct washers from ackits? and what should I ask for exactly? Thanks again.
TRB on Sun August 31, 2008 7:17 PM User is offlineView users profile
This should have you covered.
CP3016
Edited: Sun August 31, 2008 at 9:15 PM by TRB
Matt L on Sun August 31, 2008 7:20 PM User is offline
There's an extra "https//" in there.
max on Sun August 31, 2008 8:34 PM User is offline
Fixed the link and found it. Well at least my ac will be working for next summer....
TRB on Sun August 31, 2008 9:16 PM User is offlineView users profile
You would think I have adding links down by now!
