12 or 134 ?
D.T. on Fri August 29, 2008 5:03 PM User is offline
Year: 1993
Make: Buick
Model: Le sabre
Engine Size: 3800
Refrigerant Type: ????
What type of refridgerant does this vehicle use?
The manual says either or, 2 lbs 134 and 2.4 lbs 12. The low side fitting is some sort of 1/4" flare hybrid new style fitting. I can get some 12 but I need to order the funny can tap for it since no on sells this stuff anymore.
Too many questions, not enough answers....
TRB on Sat August 30, 2008 1:08 AM User is offlineView users profile
According to my data.
1993 used R12.
1994 used R134a.
mk378 on Sat August 30, 2008 1:50 AM User is offline
If you have a flare type service fitting it should be R-12. Any stickers under the hood? Usually the compressor label will mention refrigerant type, also the accumulator, though the parts may not be original.
GM Tech on Sat August 30, 2008 8:27 AM User is offline
Guaranteed -OEM was R-12
Chick on Sat August 30, 2008 9:21 PM User is offlineView users profile
Just to add, the R12 fitting on the high side "may" be the deep throat fitting GM used for a couple years, your R12 gauges won't depress the valve core if it is, you will need the GM high side adaptor..Hope this helps..
