compressor oil leak?
pkgmc on Sat August 23, 2008 1:28 AM User is offline
Year: 1999
Make: GMC
Model: Sierra
Engine Size: 5.3
Refrigerant Type: 134
I've got a 99 GMC Sierra and I noticed the other day oil leaking from the front of the compressor/clutch. The compressor is not making any noise and the air conditioning works just fine. I thought maybe this oil was coming from somewhere else but after looking closer I'm convinced its coming from the clutch area. Oil has lightly covered other parts 360 degrees around the clutch. I'll try and take a picture and post it in the morning.
Is this a typical failure mode for this compressor?
Any way to fix or am I looking at a complete compressor replacement?
Thanks!
TRB on Sat August 23, 2008 10:21 AM User is offlineView users profile
Sounds like the shaft seal is bad. They can be replaced with the proper tools.
pkgmc on Sat August 23, 2008 10:41 AM User is offline
Here's a picture. Seal leak?
TRB on Sat August 23, 2008 10:57 AM User is offlineView users profile
I edited you image, size was a little large. Very good chance its a shaft seal leak by the image. I would use an electronic leak detector and confirm this is you issue.
pkgmc on Sat August 23, 2008 11:03 AM User is offline
Thanks. Will try the leak detector. If the shaft seal is leaking would it be better to replace the seal or get a new compressor? The truck is 10 years old and has 75,000 miles on it. I understand there are other compressor manufacturers that make a much better product and if I have to remove the compressor anyway......
One other question. I've also read that changing a compressor due to a leak does not require a system flush. Is that correct? Just trying to figure out what all needs to be done.
Thanks!
TRB on Sat August 23, 2008 11:51 AM User is offlineView users profile
Personally if you don't have the correct tools I would suggest a new compressor.
I show two models for this vehicle.
COMP. TYPE=10S17F; CLUTCH TYPE=4 Gr.; w/Factory AC
COMP. TYPE=H6-SW; CLUTCH TYPE=4 Gr.; w/Factory AC
Let me know which one you have and I can check on it for you.
GM Tech on Sat August 23, 2008 12:53 PM User is offline
Yours is low mount- right? Since it is a 5.3L--- also that was a mixed bag yr ear for compressors-- I do know that the DelphiOEM pump has the double lip seal shaft seal-- is you r compressor a nippondenso unit? see if you can read the label. i
pkgmc on Sat August 23, 2008 1:28 PM User is offline
Here's a few numbers I found on the compressor:
1136610
120881300
Delphi (Harrison) 6610
Its mounted low and looks like quite a project to get it out. Here's some pics of the looking up from underneath the truck.
TRB on Sat August 23, 2008 2:00 PM User is offlineView users profile
I edited your images again. Feel free to post images but please try and limit the size to 800 pixels. Readers with dial up connections will be able to view the page in a timely manner with smaller images.
Plug and Switch location I saying that is the,
Compressor Type H6-SW Clutch Type 4 Gr. Coil Clocking 0.0833 Coil Connector Blue Pin Clutch Diameter 4.33` Number Of Grooves 4-poly
Should be our item number
20-10869
chris142 on Sat August 23, 2008 2:34 PM User is offline
It comes right out the top between the mount, exhaust manifold and heater hoses. Pull the belt off, lines and the bolts. One bolt wont come out when in the truck. Once loose and working from the top pull the rear up and twist it untill you get the right angle of the angle and it will pull right out.
Goes back in the same. Make sure you put the one bolt back into the compressor before you slide it back home.
pkgmc on Sat August 23, 2008 2:45 PM User is offline
Thanks for the info and sorry about the pic size. I thought I had reduced it but I guess not nearly enough.
About replacement - should I replace any other parts at the same time? System is working fine at the moment but I doubt I have much time left.
TRB on Sat August 23, 2008 3:13 PM User is offlineView users profile
Images not really an issue, just a suggestion on the size. I would replace the accumulator also if it were my vehicle or a customers vehicle.
