Correct rebuild kit for a-6 compressor
yosuthnmasa on Wed August 20, 2008 5:09 PM User is offline
Year: 1973
Make: Buick
Model: Centurion
Engine Size: 455
Refrigerant Type: R12
I'm pretty sure the shaft seal on my A-6 compressor is leaking. I want to replace the shaft seal and any other seals that should be replaced while doing the compressor rebuild. Which of the following shaft seal kits should I use?
https://www.ackits.com/pc/21-34612/shaftandgaskets/Shaft+Seak+Kit+-+GM+Metal
https://www.ackits.com/pc/21-34610/shaftandgaskets/Shaft+Seal+Kit
Other than the shaft seal kit, what other seals do I need? I came across this seal kit for the A6 as well:
https://www.ackits.com/pc/21-24607/shaftandgaskets/O+RING+KIT++GM+A6
Is it recommended to replace all the seals in the rebuild kit, or if I know the shaft seal is only leaking, should I replace just it?
TRB on Wed August 20, 2008 6:10 PM User is offlineView users profile
Those should work and I would just replace the shaft seal if that is all that is leaking. Might check this thread also, GM Shaft Seals.
