vents not working properly
richiebankrupt on Thu August 07, 2008 6:33 PM User is offline
Year: 2000
Make: chevrolet
Model: astro van
Engine Size: 4.3
Refrigerant Type: 134-a
Country of Origin: Uruguay
vents not blowing hard (driver/passenger), but the rear A.C. and defogger vents seem to be working good. Sometimes when I switch the fan speed or A.C. to max A.C. it will work. But that do not work anymore. Can anyone give me some ideas? Thanks
GM Tech on Thu August 07, 2008 9:05 PM User is offline
So does the air come out elswehere? like the defrost ducts? if so look for a vacuum leak - in black plastic line in front of throttle body- underhood
johnboy123 on Fri August 08, 2008 7:51 AM User is offlineView users profile
it appears that you may have a vacuum problem. under the hood on the passenger side there is a black plastic line going through the fire wall - check it out for leaks to the vacuum source. if that appears to be in good shape the problem could be on the vacuum modulator that operates the blend door and can be easily checked out. one the drivers side just above the gas pedal there is a vacuum module that operates the blend door (changing the air flow from defrost to vent/floor). see if that is in good working order. good luck
NickD on Fri August 08, 2008 9:52 AM User is offline
Either that or your air circuit, works like a vacuum cleaner cleaning up all the debris in the world that ends up on the face of your evaporator. Blower motors and circuitry aren't necessarily designed to last the life of the vehicle either, while I have commented on what the replacement cost of these toys could buy a 3 foot fan driven by a precision weather tight motor, haven't been able to make these fit.
