Compressor went to heaven/Repair plan
ghiotom on Sat August 02, 2008 12:51 PM User is offline
Year: 1996
Make: Jeep
Model: Grand Cherokee
Engine Size: 5.2
Refrigerant Type: R-134A
Well the compressor on my 96 Grand Cherokee died yesterday. The clutch was screaming like a wild animal, so I shut the engine off and turned the compressor by hand and it felt like the bearings were bad. I haven't opened up the system yet, so I don't know if there is any debris in the system from the failure. My plan is to replace the compressor, the condenser, the liquid line(with the orifice tube), and the accumulator. That leaves the evaporator and the high pressure line from the compressor to the condenser. I want to avoid flushing anything. The evaporator is only a year old so I think I will just leave it alone and use some compressed air to blow out the high pressure line. By the way, the compressor and the condenser are the originals and after nearly 13 years and 191,000 miles I guess that's not bad. Can't say that about the evaporator, though. I will be ordering the parts from this site, using nylog on the o-rings, and DEC PAG 46 in the system. If anybody has any suggestions on how to make sure this repair is successful, I would be very thankful.
TRB on Sat August 02, 2008 1:27 PM User is offlineView users profile
Should not be too much debris with the Denso compressor. After pulling the accumulator drill a big hole in the bottom of it which will allow you to drain and check the condition of the oil.
ghiotom on Sat August 02, 2008 1:52 PM User is offline
Thanks Tim. For comparison's sake, do you have a new compressor for a 96 GC V8 or just the rebuilt one?
TRB on Sat August 02, 2008 2:22 PM User is offlineView users profile
Let me know if I can help with anything else.
New Compressor/Clutch
Accumulator
Condenser
Discharge Hose
TRB on Sat August 02, 2008 5:24 PM User is offlineView users profile
ghiotom, thanks for the support! We will work on getting the order out Monday!
JJM on Mon August 04, 2008 3:09 AM User is offline
Definitely consider pulling the OT and checking for debris.
Any sign of debris and you will need to flush. Universal In-Line Filter is a good insurance policy as well.
Why the aversion to flushing? From the sound of thngs, you'll only need to flush the evaporator and discharge line... not that bad. An inexpensive Mastercool AC Flush Kit should do the job fine.
Any other questions or if you run into problems, you've come to the right place.
Joe
