cold OT/warm vent
joe_mn on Tue July 29, 2008 7:24 AM User is offline
Year: 1996
Make: caddy
Model: sts
i had a small leak from the firewall line with the OT connection. put in new o-rings but they felt a little loose. system held vacuum fine. charged and got cold air but 2 days later i have no cooling. compressor is running. the line after the OT is cold but the evap outlet is warm. low charge? shop matched original o-rings but they just don't fell snug when inserting fitting.
Chick on Tue July 29, 2008 8:03 AM User is offlineView users profile
Obviously a leak, but might just be somewhere else, UV dye should be in the system, check for leaks everywhere including the connection mentioned. Don't run it long with a low charge though, you can destroy the compressor and wind up replacing a lot more..Hope this helps..
PS: there are a lot of O rings out there, check with ackits.com for a vehicle specific O ring set if you can't find one right away..And check the front of the compressor for a possible shaft seal leak..
GM Tech on Tue July 29, 2008 8:05 AM User is offline
A '96 Caddy is highly suspect for compressor body o-ring leaks
