ring less compressor pistons
coldkeeper1 on Mon July 28, 2008 8:52 PM User is offlineView users profile
I´ve noticed that many currently available automotive a/c compressors lack rings in their pistons. How does the compression takes place once there is some wear between the piston and cylinder? Does the oil film between the two works as a seal ?
chris142 on Mon July 28, 2008 8:53 PM User is offline
I never thought about it. The old .049 Cox model airplane engines didn't have any rings either.
Chick on Mon July 28, 2008 9:08 PM User is offlineView users profile
I haven't seen one without teflon rings, I'd like to see a pic of one if you have it. They don't use rings like a piston engine, rather a band of teflon or other materil like the shed ring in this pic.. Maybe the other guys can shed some light on it..pardon the pun..
GM Tech on Tue July 29, 2008 12:01 AM User is offline
All the new CVC compresors are ringless- they have teflon coatings that are ground to size- work great as long as there are no aluminum spots showing through-- also the pistons are hollow- imagine that- air inside the compressor that never escapes!!
Chick on Tue July 29, 2008 6:22 AM User is offlineView users profile
Well, when the teflon wears out, it will be a disaster when the aluminum begins to wear against other parts....But could it possibly be as bad as when these compressors shed a ring and it gets ground up... I doubt it....
GM Tech on Tue July 29, 2008 8:15 AM User is offline
Well- its been going on since 2002-- haven't seen any major disasters yet..
iceman2555 on Tue July 29, 2008 1:12 PM User is offlineView users profile
Edited: Tue July 29, 2008 at 1:13 PM by iceman2555
