slow leak
neilh on Sun July 27, 2008 9:40 PM User is offline
Year: 93
Make: ford probe
Engine Size: 2.0
Refrigerant Type: r12
i vacuumed the system let it sit 24 hours the inches hg. drops a couple psi..whats the best way to find a small leak? i replaced the compressor with a rebuilt one..it had a shaft seal leak
Chick on Sun July 27, 2008 10:17 PM User is offlineView users profile
Over 24 hours a couple psi may mean you don't have a leak. Drop in temp and other factors may weigh in, not to mention moisture boiling off, pull another vacuum and see if it holds an hour. If it does I'd charge it up..Add UV dye to the system to aid in finding future leaks..Once pressure is in the system, it may seal any leaks from O rings that under vacuum will leak a bit. 24 hours is a long time to be under vacuum without a loss of some kind
