Oil needed when recharging after fixxing a leak?
lbquoc on Wed July 23, 2008 10:28 AM User is offline
Year: 1998
Make: Lexus
Model: SC300
Engine Size: 3.0L
Ambient Temp: 90
Pressure Low: 30
Pressure High: 150
I'm attempting to fix a leak in my AC system probably due to a bad O ring. When I evacuate the system, if the vacuum holds at 29Hg for 5-10 minutes then I can say that the leak is fixed. Is that correct? Also, do I need to add oil when i recharge the system to replace the oil lost because of the leak?
william gunkel on Wed July 23, 2008 11:11 PM User is offlineView users profile
I would fix the leak, put a couple of ozs of oil in the new dryer and evacuate the system for 30 min. and as you stated make sure it holds 29-30Hg for ten min.
1981 Merdedes Benz 300SD 1991 Jeep Cherokee Limited Edition
