What viscosity DEC Pag for '99 GM Regal ?
lght1 on Tue July 15, 2008 6:03 PM User is offline
Year: 1999
Make: Buick
Model: Regal
Engine Size: 3800 SII
Ambient Temp: 88f
Hi
What is the proper viscosity DEC Pag for the '99 Buick Regal ?
Thanks for replying :-)
1999 Regal LS
ZZP 2.5" DP, Ubend Delete
GTP duals
12" Brake upgrade
GMPP Handling Pkg
iceman2555 on Tue July 15, 2008 6:31 PM User is offlineView users profile
PAG 150....preference is for the Double End Capped...."DEC"...but 'standard' PAG will work as well. Be sure to add the lubricant to the case thru the bolt in the side. Failure to add lubricant to this location may result in some serious compressor damage.
Insure that the system is recharged properly...this compressor is prone to internal damage when operated with an insufficient recharge.
Good luck!!!!
lght1 on Tue July 15, 2008 6:35 PM User is offline
Hi
Thanks. I thought it was 150, but saw 125 mentioned in an earlier thread.
1999 Regal LS
GTP duals
12" Brake upgrade
GMPP Handling Pkg
iceman2555 on Tue July 15, 2008 9:48 PM User is offlineView users profile
125 is the GM spec, however, most lube suppliers spec the lube at 150. If not mistaken GM sells a 125 pag.....but the same company that produces this for GM specs in the aftermarket at 150.
Use the 150....but make sure it is lubed properly.....and charged completely.
Edited: Tue July 15, 2008 at 9:49 PM by iceman2555
iceman2555 on Tue July 15, 2008 9:57 PM User is offlineView users profile
Notice the 'blue' on the bearing race ...center of compressor. This bearing relies totally on the pressure differential of a properly recharged system to maintain lubricant flow.
Also notice how little lube has drained from the case. The lubricant was added to the compressor in the 'standard' method...into the suction port...however, this is an improper method and does not insure correct lubricant to the case itself.
Edited: Tue July 15, 2008 at 10:12 PM by iceman2555
TRB on Wed July 16, 2008 11:10 AM User is offlineView users profile
Interesting, does CW state in their product information on how to fill this model of compressor?
iceman2555 on Wed July 16, 2008 11:15 AM User is offlineView users profile
Currently NO....however, new instructional information is being readied for insertion....but then.....we all know what instructions are for......heck....been doing this for 'XX years'....heck boy...I know what I'm doing.....don't need no f*&&%$g instructions.....just send me another compressor.......heck....save some fuel...send two in case this other one fails also....."
Seriously....it is in the new instruction sheet. A proposal....a tape strip around the case....'saying...PUT THE DARN STUFF HERE.
If you hear from 'ice-n-topics'...or ice if you read this...give me a call....later
TRB on Wed July 16, 2008 11:20 AM User is offlineView users profile
Where is my A6 data?
I hear you on the instructions! Get's frustrating at times when you explain a process and then it's not followed. Only to be then followed with why is it not working!
iceman2555 on Wed July 16, 2008 5:49 PM User is offlineView users profile
My contact at 'that place' is not longer there....his 'vacation' was a bit more.....seems he is moving to China.....gonna make A6's over there....NOOOOOO!!! that was a slight attempt at some humor.....have to determine if there is another that can help......in the big "D" this week...Ill ask purchasing tomorrow for a contact
