HT-6 problems?
Brad on Mon July 14, 2008 10:59 PM User is offline
Year: 1996
Make: Chevrolet
Model: Suburban
Engine Size: 7.4
Refrigerant Type: r134a
Pressure Low: 110
Pressure High: 110
I have a '96 Suburban w/ dual air. A leak at the high side fitting was repaired, evac'ed and recharged. But it would only take 1 lb. Low side was as at 110 psi, same as the high side. Replaced orifice tube which was clogged with what appears to be aluminum filings. Still will only accept 1 lb and has high low side pressure. I believe it has a HT-6 compressor. Could this be the problem. Thanks.
Dougflas on Tue July 15, 2008 5:11 AM User is offline
Is the clutch engaged?
GM Tech on Tue July 15, 2008 7:51 AM User is offline
Those filings were probably stainless steel- from an imploded compressor- that has lost nearly all its suction reeds- does the compressor turn very easily with one finger? does it have little "catches" as you rotate it? Is the compressor running with the 110 psi suction pressure? If all three things check positive, then you are in need of a new compressor..
Brad on Tue July 15, 2008 6:02 PM User is offline
The compressor turns fairly easy, but not with 1 finger. I did not notice any "catches". Yes the compressor did engage for short cycles(5-10 seconds) with the high pressure on the low side. The problem did not change with or without the a/c on.
