Low presuure switch leaking
One Ton on Tue July 08, 2008 3:14 PM User is offline
Year: 1998
Make: Chev
Model: C3500
Engine Size: 7.4
Refrigerant Type: 134
The low pressure switch on the side of the accumulator is leaking. Is there an o-ring to replace (what size) or one of those GM seals? OR Should I just replace the switch and seal as one?
Thanks for the help.
JC
GM Tech on Tue July 08, 2008 4:29 PM User is offline
Number one cause of a leak at that location is overtorquing that plastic base switch- look for a hairline crack in the base- if such is the case- then switch needs replaced- o-ring will come with it-- pull off old- o-ring first- then lube and roll new o-ring onto port over threads- then snug down switch to about 4 inch-pounds- or just beyond finger snug.....no new to discharge system to replace this switch..
GM Tech on Tue July 08, 2008 4:30 PM User is offline
Number one cause of a leak at that location is overtorquing that plastic base switch- look for a hairline crack in the base- if such is the case- then switch needs replaced- o-ring will come with it-- pull off old- o-ring first- then lube and roll new o-ring onto port over threads- then snug down switch to about 4 inch-pounds- or just beyond finger snug.....no need to discharge system to replace this switch..
Edited: Tue July 08, 2008 at 5:36 PM by GM Tech
One Ton on Tue July 08, 2008 4:51 PM User is offline
I'm just going to replace the switch they're not that expensive. I already
figured out that I can replace it without breaking into the system. Is Nylok ok for the o-ring and threads?
Edited: Tue July 08, 2008 at 4:55 PM by One Ton
Chick on Tue July 08, 2008 8:04 PM User is offlineView users profile
Lube the new O ring with oil or nylog and when you screw the new switch on, don't over tighten, hand tight is fine..As GM tech stated, they do crack if you try to tighten them to much..hope this helps..
One Ton on Tue July 08, 2008 8:56 PM User is offline
THANKS FOR THE HELP!!!!!!!!
I'll let you know how it goes.
Edited: Tue July 08, 2008 at 8:57 PM by One Ton
One Ton on Fri July 18, 2008 9:50 AM User is offline
THANK YOU FOR THE HELP!!!!!!!!!!!!!!!!!!!!!!!!!
No more leaks. Nylog is way cool.
Truck is soooooooo cold inside I'm thinking of renting out space as a meat locker.
Thanks again!
BTW I'll be back with the site sponsor when it's time to work on the AC in my 72 Impala. The compressor was in the trunk when I bought it.
Edited: Fri July 18, 2008 at 9:57 AM by One Ton
