INCONCISTANT CLUTCH
DEANCO1 on Thu July 03, 2008 1:29 PM User is offline
Year: 97
Make: FORD
Model: E150
Engine Size: 6CYL`
Refrigerant Type: 134A
AC CLUTCH ENGAGES THAN STOPS . AC BLOWS WARM AIR. LAST SUMMER AIR WAS ICE COLD
KIM R DEAN
Chick on Thu July 03, 2008 1:41 PM User is offlineView users profile
Check the clutch gap, should be .02 or less (without scraping) especially if it does it when hot more than cold, also a common problem is the cycling switch. When it stops working, tap the front hub of the clutch, if the compressor starts working again, most likely clutch gap adjustment..Let us know what you find..hope this helps
DEANCO1 on Thu July 03, 2008 1:59 PM User is offline
THANKS FOR INFO WILL TRY TAPPING CLUTCH AND ALSO CHECK GAP
KIM R DEAN
Chick on Thu July 03, 2008 2:56 PM User is offlineView users profile
When it works, is it cold? If not, you may have a leak, I am guessing it blows cold then stops??? Pressures will be needed if it's not the clutch gap or cycling switch..
