low side pressure ?
mxz583 on Tue July 01, 2008 6:44 PM User is offline
Year: 1997
Make: chevy
Model: express G1500 Van
Engine Size: 5.7
Ambient Temp: 82
Pressure Low: 50
Pressure High: 210
my low side pressure is at 50 that seem a little high. the high side is at 210 what could cause a high low side
TRB on Tue July 01, 2008 10:30 PM User is offlineView users profile
How does the condenser look. Does it have a lot of bugs or bent over fins? Second thing to check is if the fan clutch is working correctly. You may not be drawing enough air through the condenser. The mist the condenser with water may help indicate an air flow issue.
Chick on Wed July 02, 2008 12:23 AM User is offlineView users profile
Could have a partial charge or bad reed valves. I would recover the refrigerant, recharge after checking the O tube, and then get the pressures..Hope this helps..
