Year: 2000
Make: chevrolet
Model: silverado 1500
Engine Size: 4.3
((Direct Replacemet for AC Delco #15-20151 SD7H15/ HT6 SANDEN #4440))
will this compressor replace a delphi #15765036 ?
It 'appears" there are a couple different compressors that year, check out 2000 silverado on ackits.com list and see which one you have. The HT6 is the most common one that they make replacement Sanden and Seltec compressors for, but first step is seeing which one you have..
this is from the ackits web sight...just want to make sure before i order...mine hase 4 cross mounts and no ear mount..it looks like the right one
That would be the HT6 then, all mounting bosses are the same height? then it's the HT6 and the replacement compressors are the right ones...
The lines go right on top centered, not offset like the Nippondenso where as you look, the lines are offset to the mounting bosses..
Edited: Sun June 29, 2008 at 9:50 PM by Chick
yes the line go on top center on the compressor that i'm replacing...ty for your help, i feel better about ordering this compressor now
