Compressor new seal lubrication type?
bearing01 on Fri June 27, 2008 12:34 PM User is offline
Hey all,
I'm putting new seals and gaskets in a Bosch-Behr wing cell vane type compressor.
I have read that you shouldn't put PAG on O-rings when installing fittings. My books say to use "regular refrigerant oil" on O-rings and elsewhere it says to use petroleum based refrigerant oil. The shaft seal is the 2-piece spring loaded seat type. It's an R134a retrofit and I'll be using PAG in the end.
Question: When putting her back together should I use PAG, Mineral oil, or something else like Nylog on all the compressor O-rings and seals?
TRB on Fri June 27, 2008 12:38 PM User is offlineView users profile
Nylog is fine of you have it. Otherwise mineral oil.
PS: Chick puts Nylog on his corn flakes. I personally think that's a little much.
GM Tech on Fri June 27, 2008 12:55 PM User is offline
Pag oil attracts moisture- don't want to rust up connections
