99 chevy 5.7 pressures?
daman on Mon June 23, 2008 9:44 PM User is offlineView users profile
Year: 1999
Make: chevy
Model: K1500
Engine Size: 5.7
Ambient Temp: 75
Pressure Low: 20
Pressure High: 175
I have the factory amount in,2lbs(32oz's),pressures seem low,engine fan is good vent temps 40ish why they showing low,orifice is new, old one looked good,inlet and out let temps on the evap are the same temp(cold)some frost on low pressure line going out of the comp.????
Edited: Mon June 23, 2008 at 9:45 PM by daman
GM Tech on Mon June 23, 2008 10:24 PM User is offline
it is only 75 degrees out -- that's why
daman on Mon June 23, 2008 10:34 PM User is offlineView users profile
I was thinking that too,, but my FSM shows it should be a little higher,,i guess i'm good then,i'll leave it alone.
MrBillPro on Mon June 23, 2008 10:34 PM User is offlineView users profile
Spray some water on the condenser and make sure your LPS is working, I have the same truck and my LPS opens at around 18 psi it may be yours is not working if your suction line is starting to freeze "OR" you could still be a tad low on refrigerant. I am am Home a/c professional and I personally would never trust a weighed in charge to many variables, but maybe you can get away with it on a vehicle.
Don't take life seriously... Its not permanent.
Edited: Mon June 23, 2008 at 10:35 PM by MrBillPro
daman on Mon June 23, 2008 10:40 PM User is offlineView users profile
Sorry whats a LPS,more info please?
MrBillPro on Mon June 23, 2008 10:50 PM User is offlineView users profile
Sorry, "Low Pressure Switch" most of the factory ones are fixed "non adjustable" I installed an adjustable one on my truck and tweaked
the charge it will freeze you out on 100 degree days in Houston.
daman on Mon June 23, 2008 10:53 PM User is offlineView users profile
Ok yea how'd i miss that,lol anyway yea mine is working ok i think kicks off at around 18-17 psi wile
temps were 75 today,sound ok??
chris142 on Mon June 23, 2008 10:56 PM User is offline
temps were 75 today,sound ok??yup
daman on Tue June 24, 2008 7:52 AM User is offlineView users profile
K thanks guy's...
Edited: Tue June 24, 2008 at 8:04 AM by daman
GM Tech on Tue June 24, 2008 8:19 AM User is offline
Sure would look funny- having all those technicians in the assembly plant "tweaking" in the a/c charge amount so that they will work in Southwest, Northeast, Northwest, Southeast, all at the same time.....
Assembly plants actually use a big cylinder - like an oversized syringe" to put the exact amount in as tested for in the wind tunnels,,,,,
MrBillPro on Tue June 24, 2008 10:21 AM User is offlineView users profile
But I already knew that, and I did not say this was a good idea to do as I did, I just said that this is what I did "BECAUSE" I do know what I am doing, remember I was an auto mechanic for 10 years before I got into the commercial and residential a/c business and I am even ASE certified from way back in 1972 been to the GM factory
back in 1969 that was a really nice experience, I may not show up much around here, but Tim will tell you that Mr. Bill is not clueless when it come to
automotive a/c I do have a clue.
Edited: Tue June 24, 2008 at 10:23 AM by MrBillPro
GM Tech on Tue June 24, 2008 10:35 AM User is offline
Sorry if I offended you-- but I couldn't resist thinking of charging cars in the same way home units are done---I did not even look at who posted the comment..... guess you can't have any fun sometimes.....
MrBillPro on Tue June 24, 2008 10:47 AM User is offlineView users profile
Hey don't worry about it I was not offended at all I just basically wanted to explain that I do understand were your coming from as for as weighing in the charge, but I can tell you from experience you can tweak your auto a/c "if you have an adjustable LPS" and you know what your doing for your local, would it be profitable for GM or any other mfg. to do this of course not.
Edited: Tue June 24, 2008 at 10:47 AM by MrBillPro
TRB on Tue June 24, 2008 10:54 AM User is offlineView users profile
What's more important in this thread. Is how many grammar and spelling errors we can find!
Obviously any system can be tweaked a little from OEM. I'm sure GMTech has a few tricks up his sleeve many of us don't know. I also know the party line dealer mechanics pull sometimes is laughable. If an item does not drop into place for them! They have no will to see why it won't fit. I have fixed many R134a factory systems by tossing there condenser and installing a FSHE PF unit. Yep I had to make hoses and I changed the OEM configuration. But it was cooling in 110 plus AZ heat when it did not with the OEM setup.
MrBillPro on Tue June 24, 2008 11:09 AM User is offlineView users profile
Hey I am from Texas I have an excuse.
brickmason on Wed June 25, 2008 1:17 AM User is offline
Ok boys, GM Tech go stand in that corner, Mr bill you go stand in that corner, Tim come here your getting a whipping.
Just another brick in the wall
Had a little mule I fed him castor oil and every time he jumped the fence he fertilized the soil
