pressure went up to 500 and them something blew in compressor
mainorm on Mon June 23, 2008 2:50 PM User is offlineView users profile
Year: 1998
Make: hinday
Model: sonata
Engine Size: 3.0
Refrigerant Type: r134a
Pressure Low: 40
I fix a leak on this car vacumm and then recharged the sistem pressure started to climb to over 500psi and then somenthing blew in the compressor could this be due to a fail high pressure swicht, what should i do now?
mk378 on Mon June 23, 2008 3:02 PM User is offline
You're right, the compressor should have shut down. If refrigerant blew out of the compressor it could have had a relief valve, which will either hopefully re-close by itself or be seperately replaceable.
If you didn't overcharge, the most likely reason for excessive pressure is that the condenser fan does not work.
