Blows harder when you accelerate
2000_civic on Sun June 22, 2008 12:41 AM User is offline
Year: 2000
Make: Honda
Model: Civic
Engine Size: 1.6
Refrigerant Type: 134
What would cause the blower to put out more air when you accelerate? Not colder air, just more of it. If I'm idling at a stop lite with the blower set to high, it blows air. When I accelerate the blower puts out more air. If I take my foot off the gas with the clutch disengaged the air output drops back down to what it was at idle. I'm about to redo my system and would like to know if this is a problem I should take care of while I'm in there.
bigkev on Sun June 22, 2008 2:24 AM User is offline
Chick on Sun June 22, 2008 5:43 AM User is offlineView users profile
It could be more of the sound getting louder? Like a vacuum door moving. You may want to check for a vacuum line loose or cracked?
chris142 on Sun June 22, 2008 10:25 AM User is offline
Sounds like the Alternator can't keep up @ idle.
2000_civic on Mon June 23, 2008 6:22 PM User is offline
Thanks for the replies! I'm going to check the vent system while I have everything pulled apart. I'm going to check the alternator too, I think it might have an oversized pulley on it. Got rained out this weekend. Hopefully I can get it done this coming weekend.
mk378 on Mon June 23, 2008 6:48 PM User is offline
Does sound like a voltage drop. A little of that is normal especially if you have other electric accessories on. Don't run oversized pulleys, the stock configuration is barely adequate. You're unlikely to gain any noticeable hp anyway because the alternator will just pull more torque when it is underspun.
2000_civic on Mon June 23, 2008 8:12 PM User is offline
I'm not a big fan of the oversized pulleys myself. Especially on a daily driver. I think they do more harm than good.
