TXV or low refrigerant? Or something else?
pdrayton on Thu June 19, 2008 11:08 AM User is offlineView users profile
Year: 1983
Make: Mercedes
Model: 240D
Engine Size: 2.4l
Refrigerant Type: R12
Ambient Temp: 85
Pressure Low: -10
Pressure High: 150PSI
This has me way confused, but I'm sure someone here knows the answer.
Compressor off - low and high side are both around 100psi
Compressor on - low side drops to -10 (vacuum) and hi side goes to around 150-180psi.
The mercedes factory manual says hi side should be around 350psi at this ambient and humiditiy (55%).
So this looks like a classic "not enough refrigerant" situation right?
Except that when I switch the AC off, the pressures take about 10 minutes to equalize. So it is like the TXV is stuck, or is the taking a long time to equalize just a symptom of low refrig?
I'm stumped, and don't want to pull all the R12 out to replace the TXV if it is not the problem.
Thanks guys.
1983 Mercedes 240D on R12 and WVO!
1192 Mercedes 300D 2.5 R134a
1993 Toyota Pickup converted to R134a
TRB on Thu June 19, 2008 11:41 AM User is offlineView users profile
I would pull the refrigerant and find out how much is in the system. What you described here is just a system pulling into a vacuum do to a very low refrigerant level.
pdrayton on Thu June 19, 2008 12:55 PM User is offlineView users profile
Thanks TIm.
After calling 3 ac shops in town who all told me they couldn't take out the refrigerant becuase it was R12 and they weren't 'qualified' to work on mercedes, I thought I'd try a different route.
However, I have a question - is the slow equalization of pressures normal? Is it not an indicator of another problem? How would a stuck TXV behave?
pdrayton on Mon June 23, 2008 7:34 AM User is offlineView users profile
Well, I found the problem - leaking condenser.
I got a propane torch and some aluminum rods and did a test weld on an old radiator. No dice.
anyone know the trick to brazing aluminum - do you need that special flux stuff? what kind of torch? the propane torch didn't melt the aluminum brazing rod very well.....
Any suggestions? Seems a shame to put in a whole new condenser for a tiny hole...
GM Tech on Mon June 23, 2008 7:54 AM User is offline
If you start "fixing" that tiny hole on your condenser- it will soon be a big hole-- and what is to say that there are not more tiny holes waiting to spring a leak? I've never known anyone to be able to fix a condenser--so I never try it-- just spring for the new one--
besides... it IS a Mercedes.......
Edited: Mon June 23, 2008 at 7:55 AM by GM Tech
pdrayton on Mon June 23, 2008 11:01 AM User is offlineView users profile
yes, is IS a merc, but it is an 1983 and it's a beater which I won't have for much longer. $250 for a condenser is more than a 1/4 of whatI paid for it! Good car though. And since I'm using ES12 ($6 a can, 3 cans for afillup) I don't really mind if it leaks. If it does, then I can try again...
plongson on Mon June 23, 2008 4:51 PM User is offlineView users profile
Unfortunately:
There comes a time when expensive repairs out weigh the value of the vehicle. Modern air conditioning systems fall into the same category as engines and automatic transmissions.
Fortunately:
One can make the decision to continue driving said beater without air conditioning.
Vibration Analyst in Power Generation
