low side pressure low
echeeves on Thu June 19, 2008 9:50 AM User is offline
Year: 2001
Make: Toyota
Model: Tundra
Engine Size: 4.7
Refrigerant Type: R-134a
Ambient Temp: 71
Pressure Low: 5
Pressure High: 90
what would cause such low pressure on the low side?
I know it has a low charge but looked lower than i have ever seen one.
GM Tech on Thu June 19, 2008 10:16 AM User is offline
Wait a few days, weeks, months and it will go even lower---as you loose refrigerant it will eventually go to zero or even vacuum-- you obviously have a leak- that needs to be found, fixed and recharged to factory spec.....my guess is you have about 1/4 of the necessary refrigerant in the system.....you don't want to run it in that condition for long- it will damage your compressor...
echeeves on Thu June 19, 2008 10:36 AM User is offline
ok, cool. i didn't know it would go that low and let the compressor kick in!
thanks
I will check for leaks and repair as needed
echeeves on Thu June 19, 2008 11:21 AM User is offline
I did not see any oil around fittings so I put some 134 with dye in the system till my gauges read 32 low 200 high. I will monitor for leaks. I have another question though. the low side on my gauges only slightly moves even if I disconnect the adapter. is this normal?
