magical fittings?
bigkev on Wed June 18, 2008 2:07 AM User is offline
Has anybody else tried to shop for ac fittings? No thread size or pitch is ever listed I checked. Maybe these are magic fittings that transform into the size you need when you get them. Every site I came across does a good job of listing the tube size and the angle but no info on the threads.
Also, has anybody tried out alumaloy brazing rods or braze perfect?
http://shopping.keepitkool.net/index.php?act=viewProd&productId=18&PHPSESSID=567f7e24ea690c26fd09401e3a5fa024
Edit: Sorry no Auction links permitted on this forum. TRB
Edited: Wed June 18, 2008 at 1:24 PM by Automotive Air Conditioning Information Moderator
TRB on Wed June 18, 2008 1:29 PM User is offlineView users profile
I used it in the past and this works better in my opinion. We use Oxygen and Acetylene torches. But this rods can be used with a MAP gas setup.
Aluminum Braze Rod
bigkev on Thu June 19, 2008 12:02 AM User is offline
thanks, I will order and try them out.
TRB on Thu June 19, 2008 12:38 AM User is offlineView users profile
Thanks for the support.
HECAT on Thu June 19, 2008 1:25 PM User is offline
The thread sizes are standard to the tube sizes that is why they are sometimes not specified.
For SAE 45 degree flare & beaded o-ring (long & short pilot):
1/4 7/16-20
3/8 5/8-18
1/2 3/4-16
5/8 7/8-14
3/4 1 1/16-14
Metrics are a different story
