Scout with AMA kit
scout4bta on Tue June 17, 2008 3:10 PM User is offline
Year: 1980
Make: IH
Model: ScoutII
Engine Size: 3.9L
Refrigerant Type: R134A
Ambient Temp: ok
Pressure Low: ok
Pressure High: ok
to all at AMA
I've been using the AMA kit in my Scout for over a year and half and can say it works real good! Had a reading 40F at the vents on a trip down to Tucson last year when the outside temps were over 110F. Now if I ever get around to replaceing the door seals it might even get cooler inside.
Steve
wrenwright on Tue June 17, 2008 4:02 PM User is offlineView users profile
Steve,
Can you supply some more info about your system? Compressor, etc.?
I've got a '72 1210 and am interested in what you did to get a/c in your binder.
Thanks.
scout4bta on Wed June 18, 2008 8:14 AM User is offline
Originally posted by: wrenwright
Steve,
Thanks.
scout4bta on Wed June 18, 2008 8:22 AM User is offline
Steve,
Thanks.
Nothing special, used the largest, condenser I could fit up front. Used the AMA kit(evaporator) for the Scout, The compressor is a Sanded, bought the tools, fittings, made my own lines, followed the instructions and it's cold!
Steve
chris142 on Thu June 19, 2008 9:22 PM User is offline
I have a 73, 1210 pickup. It had a smaller under dash unit mounted under the hood when I got it. Mine is a 4sp and someone had already heated the shifter up and bent it but I still could not use 1st or 3rd gear because the AC unit was in the way.
You may have the same problem if yours is a stick shift.
wrenwright on Sat June 21, 2008 12:57 PM User is offlineView users profile
My 1210 has a 727 in it, so the shifter woulndn't be an issue unless the transfer case shifter becomes a problem as I've considered converting it over to 4wd.
