Universal inline filter
mrvmax on Fri June 13, 2008 6:15 AM User is offline
Year: 1996
Make: Ford
Model: F350
Engine Size: 7.3
I am purchasing the universal inline filter from AMA. Do I remove the orifice from it's currentlocation and install in this filter or do I leave it where it is on teh vehicle?
HECAT on Fri June 13, 2008 8:25 AM User is offline
The orifice feature of the filter/splice is designed to use as a repair if the stock location of the orifice is damaged. If your stock location is not damaged, keep the original orifice in its original location and use the filter less its included orifice as a filter only. Hope this helps.
mrvmax on Fri June 13, 2008 6:41 PM User is offline
Thanks you, that helps. Now I just need to wait for my filter to get here.
TRB on Fri June 13, 2008 8:49 PM User is offlineView users profile
Staff should have emailed a tracking number. If not let me know and I'll get one for you.
mrvmax on Fri June 13, 2008 9:22 PM User is offline
I forgot to order oil, should I use BVA or PAG? I am flushing my system (I have a new compresser, drier, both lines and will install the filter). Only the evap and condenser are old so I want to flush them out and remove all the old oil and add the 11 ounces recommend.
TRB on Fri June 13, 2008 10:04 PM User is offlineView users profile
DEC PAG is fine in my opinion.
