97 civic total a/c system oil capacity
Salyerlp on Mon June 09, 2008 3:04 PM User is offline
Year: 1997
Make: honda
Model: civic
Refrigerant Type: R134A
I need to know the total system capacity of pag 46 for this system. Flushed all the lines and replaced compressor, conser, evaporator and drier.
Pete Salyer
TRB on Mon June 09, 2008 3:49 PM User is offlineView users profile
5 ounces
Salyerlp on Mon June 09, 2008 3:55 PM User is offline
the compressor holds 4 1/2 oz and the repair manual agrees with that. How could the entire rest of the system only hold 1/2 oz? I'm replacing all components except the lines.
Pete Salyer
TRB on Mon June 09, 2008 4:27 PM User is offlineView users profile
My data says total is 5 ounces. But I don't think you would hurt anything at 6. But you need to be careful with the scroll compressor.
Salyerlp on Mon June 09, 2008 4:54 PM User is offline
Thank you. glad I checked. I put 1 2/3 oz in the evaporator, 1 oz in the condensor, 1/3 oz in the drier and 4 1/2 oz came in the compressor. That means I have 7 oz in the system. I haven't run it yet thank goodness. I'll take the compressor off and drain 2 oz out before I evacuate and recharge the system?. Should that be ok?
Pete Salyer
Salyerlp on Mon June 09, 2008 4:56 PM User is offline
My math was wrong. That means I have 7 1/2 oz in system. I guess I should remove compressor and drain 2 1/2 oz out.=
Pete Salyer
mk378 on Mon June 09, 2008 5:01 PM User is offline
Don't use the oil that comes in a new compressor. It may have absorbed water during storage. Drain as much as you can and put in the proper amount new.
The total system number is the one to go by in a situation like yours where everything starts dry. The numbers for each component are a conservative guess based on just replacing that component.
Salyerlp on Mon June 09, 2008 5:10 PM User is offline
Okay so the other components 3 oz of fresh pag 46. So you're saying drain all the oil from the compressor and replace with 2 oz of oisl for total of 5 oz?
Pete Salyer
