r4 clutch plate tool
awc on Mon June 09, 2008 12:42 PM User is offline
Year: 82
Make: chevy
Model: Truck
Trying to remove clutch plate. The clucth plate remover I have will not screw in. It goes on about one thread & stops. It's robinair #10861. For R4/A6 compressors. Thanks!
TRB on Mon June 09, 2008 3:45 PM User is offlineView users profile
Sounds like it has the wrong thread count. I.E. Standard and Metric.
awc on Mon June 09, 2008 4:33 PM User is offline
Tim, I think you right. I tried it on another R4 I had, it seemed to scewed in better on that one. That compressors clutch looked like item #33-2995N. The clutch hub it won't fit looks like item #20-10403. Did they change from standard to metric at some point on the clutch hubs? Do you have the part number I need?
TRB on Mon June 09, 2008 4:44 PM User is offlineView users profile
This would be the kit I would suggest.
91000-A
Edited: Mon June 09, 2008 at 10:47 PM by TRB
awc on Mon June 09, 2008 10:42 PM User is offline
The link didn't work but I still found it on your site. After doing a little search, I think around 1980 they did start using metric. I found a reference that says "will not work with metric threads". I assume this is the clutch plate hub threads & not the shaft. Is this correct?
TRB on Mon June 09, 2008 10:47 PM User is offlineView users profile
Works now.
terryk on Mon June 09, 2008 11:49 PM User is offline
That has both the metric and standard thread hub puller for the R4?
TRB on Tue June 10, 2008 12:20 AM User is offlineView users profile
I do believe so, I can double check in the morning. Send me a email and remind me to check. Getting busy and I get side tracked at times during the summer.
Chick on Tue June 10, 2008 6:09 AM User is offlineView users profile
That kit has it all, here's a pic of the inside of mine..Same kit...
GM Tech on Tue June 10, 2008 8:41 AM User is offline
The old style R-4's (the ones with bolt on pulley rims) used the same thread and remover as the A-6, The newer style clutch assemblies use the same as the V-5 and H-6- these are easily recognizable by the pulley configuration-- the newer ones have welded pulleys...not bolted on.....
terryk on Tue June 10, 2008 5:20 PM User is offline
No way, I have you on another adventure...!!
TRB on Tue June 10, 2008 6:10 PM User is offlineView users profile
Originally posted by: terryk
Which one is that?
terryk on Tue June 10, 2008 6:13 PM User is offline
My compressor that is locking up in my Fiero.
TRB on Tue June 10, 2008 6:21 PM User is offlineView users profile
I don't even have that yet.
terryk on Tue June 10, 2008 6:30 PM User is offline
I sent an email. I don't want to hijack this thread. Anymore than I have.....
Edited: Tue June 10, 2008 at 6:31 PM by terryk
