pressures correct for temp humidity ?
skiman762 on Thu June 05, 2008 11:53 PM User is offline
Year: 1995
Make: Dodge
Model: Ram 1500
Engine Size: 5.2
Refrigerant Type: 134
Low Side: 32-40
High side: 190-220
At 80 degrees ambient.
at 95 degrees and 82% humidity what will the pressure ranges be ?
Edited: Fri June 06, 2008 at 9:35 AM by skiman762
skiman762 on Fri June 06, 2008 9:16 AM User is offline
ok here's the readings after service
replaced O tube and Accumulator deep vacuumed and serviced
@1700rpm
94degrees
humidity 70%
low 41
High 220
also the metal part of the hose from the accumulator to the compressor was frosting but not on the other side of the connection
water was draining form the evaporator in a steady stream
Edited: Fri June 06, 2008 at 5:18 PM by skiman762
