How to remove clutch
medium1 on Thu June 05, 2008 8:33 PM User is offline
How in the world do you remove the clutch from a 2000 saturn s series compressor? There doesn't appear to be anything to connect a puller to.
GM Tech on Thu June 05, 2008 10:31 PM User is offline
Are there not 3 threaded holes in the front? use your steering wheel puller if so-- if not then it is a slip fit and yours is stuck- so it needs to be unstuck
medium1 on Thu June 05, 2008 11:22 PM User is offline
No, no holes there are 3 round pads the size of a bottle cap, do they unscrew? I tried to turn one but it wasn't turning and I didn't try to force it.
Chick on Fri June 06, 2008 6:23 AM User is offlineView users profile
It's a slip fit, you might need two opposing screw drivers and "gently" wiggle it until it frees up. Remove the center bolt of course..Be careful not to distort the outer clutch driver though..The three pads do not screw off...
medium1 on Fri June 06, 2008 11:42 AM User is offline
thanks
medium1 on Fri June 06, 2008 6:47 PM User is offline
I bought a used compressor for the clutch coil and to practice removing and reinstalling the parts before messing with the one on the car. The clutch came off very easy so did the pulley and coil. Thanks again.
