Help! Bad New Compressor?
pf24 on Tue June 03, 2008 7:01 PM User is offline
Year: 1997
Make: Pontiac
Model: Bonneville
Engine Size: 3.8
Ambient Temp: 55 F
Pressure Low: 65
Pressure High: 135
I am restoring air to a car that hasn't had working air in 2 years.
I installed a NEW Delpi-Harrison Compressor, accumulator, and orifice Tube. I backflushed the system with flush and clean. It held perfect vacuum for 1 hour.
Installed 8oz PAG-150 oil and 32oz R-134a and dye. Not cooling, LS 65 and steady, HS 135, Amb Temp 55 F.
I then recovered refrigerant and checked for a clogged orfice tube, it was perfectly clean. Checked for obstruction, everything flowing freely. recharged and tested with same result.
Is this a bad new Delphi-Harrison Compressor? Anything else I can do?
Thank you in advance for any info,
-Pete
Chick on Tue June 03, 2008 8:23 PM User is offlineView users profile
Low side to high, high side low..But 55 degrees is not the best for charging a system..Looks like a control valve issue though..Could be sticking.. Is that the sticker amount you put in?? (R134a)
GM Tech on Wed June 04, 2008 9:44 AM User is offline
Your head pressure says it is pumping fine- just that you are at extremely low ambient to tell what it can do-- my guess is that it is fine- wait till it gets hot out and test- or put it in a heated garage-- I have tested good V-5 systems while driving at 65 mph- at 78 deg amb- and the head pressures are 120 or so-- so don't expect high head pressures when conditions don't warrant it-- plenty of air flow acrooss condenser means lower head pressures--
Now the low side pressure is fairly high- -- low side should range from 25-35 on a Variable pump.. the "not cooling" is due to the high low side pressure- which could very easily mean overcharge- 135psi is somewhat high for that ambient- again an indicator of overcharge--I would extarct the charge and introduce a little at a time and watch the low side- when low side is about 30 psi- I bet it cools--
pf24 on Wed June 04, 2008 10:28 AM User is offline
Thanks for the help.
I found that on the V5 compressor there is a control valve internal to the rear head, it must of been stuck. With it running, I did some blows to the rear lower of the compressor with a plastic hammer. The suction tube immediately got cold.
This was on a new compressor.
bobbyrae on Wed June 04, 2008 11:29 PM User is offline
Wow! It sounds like you fixed your problem with a hammer! How trite. Have you checked the low and high side pressures after this? Just curious how much difference.
pf24 on Mon June 09, 2008 2:10 AM User is offline
I only retook low side readings,
At 75 ambient, low side was 45 PSI. Evap discharge air temp was 49 deg. Sound proper? Good enough for me.
