My Turn
Bulldog Steve on Tue May 27, 2008 2:17 PM User is offlineView users profile
Year: 1990
Make: chevy
Model: Corvette
Engine Size: 5.7
Refrigerant Type: r-12
Hello,
Well you guys helped me fix my wifes neon and she is very thankful for that in many ways.
Now its my vette that i am needing to fix. it has not worked for about 3 yr's. It has the electronic control head. I have the factory service manual.
Preformed the test on the system as per manual and it shows no faults.
It has a slight pressure if i hook up the gage set. And if i jump out the low pressure sw. the comp. will run (i only let it run for a second)!
I was told with a car that is almost 20 yr's old that the gas might have just seeped through the hoses and fitting and just be normal loss. It does not show oil on the underside of the hood or around the front seal on the comp.
So where should i start. As always thanks for what you do here to help us.
Steve
