2000 Saturn s series cllutch coil
medium1 on Mon May 26, 2008 2:38 PM User is offline
Year: 2000
Make: saturn
Model: s
Engine Size: 1.9
Refrigerant Type: r134
The clutch coil is open and needs to be replaced. How much trouble is it to replace on this car?
GM Tech on Mon May 26, 2008 10:29 PM User is offline
Hardest part is getting the clutch driver off- if it is anything like the '93 S-series I just did-- look for the three threaded holes on the driver- if they are there- then you will need a 3 slotted puller and the right screws to get the press fit spline apart- can be a real bear- I spent over an hr once doing it-- the new one will be slip fit---
Your '00 may be slip fit- if so, you can wiggle it out......
medium1 on Thu June 05, 2008 9:14 PM User is offline
There are no holes, no threads no nothing. I cannot see how to remove it. I have pictures I can send.
