Cleaning
mlelah on Wed May 21, 2008 9:13 AM User is offline
Year: 1989
Make: Honda
Model: prelude
Engine Size: 2.0
Refrigerant Type: R12
Hi, I'm replacing my condenser and drier in preparation for converting from R-12 to R134. Before putting everything together to evacuate and fill, how should I clean the original fittings and connectors? Thanks.
TRB on Wed May 21, 2008 10:35 AM User is offlineView users profile
Why do they need cleaning? Soft bristle brush and use Nylog on the new o-rings.
mk378 on Wed May 21, 2008 10:47 AM User is offline
I use paper towels. O-ring seals can tolerate some dirt, but the thing that will cause leaks is fibrous stuff like cloth fibers or hair.
mlelah on Wed May 21, 2008 6:20 PM User is offline
Thanks. It looks like there is something kind of lubricant the threads. I'm guessing that this is Nylog?
Do regular nylon O-rings work or are there special O-rings for automotive a/c applications? Thanks.
mlelah on Thu May 22, 2008 12:25 PM User is offline
What's an alternative to Nylog that I can purchase at my local store? Thanks.
GM Tech on Thu May 22, 2008 2:23 PM User is offline
Why would anyone put anything but some light oil (refrigerant oil) on the threads of a connection? -- That is the way the assembly plant factories always did it- before they went to manifold connections......
TRB on Thu May 22, 2008 2:30 PM User is offlineView users profile
One reason would be to help the GM evap connections from seizing up on many rear systems. Most industry or repair shops have used oil in the past. But why not use a better product when it's available!
mlelah on Fri May 23, 2008 10:20 AM User is offline
Does anyone know what kinds of stores sell either Nylog or refrigeration oils? I don't have time to wait to order on-line, but I can't find these products anywhere. Thanks.
TRB on Fri May 23, 2008 10:32 AM User is offlineView users profile
Johnstone
