Re-use Fitting?
JR911 on Sun May 18, 2008 5:39 PM User is offline
Year: 1986
Make: Porsche
Model: 911
Engine Size: 3.2
Refrigerant Type: will be 134a
Hello,
I'm up-dating (to 134a) my whole a/c system with new components, adding a parallel cond. and new hoses/fittings from our host. There is one fitting that may be a Porsche part only, I'm not sure. Can this fitting be re-used if I cut off the ferrule? See pics below.
Thanks in advance!
J.R.
bohica2xo on Sun May 18, 2008 6:10 PM User is offline
You have a couple of choices.
A) You can cut the ferrule away, and rework it for barrier hose.
B) Use an off-the-shelf 180 degree fitting, and add a cushioned clamp for the hose assembly instead of the welded on clip.
Either one works, and obviously Tim can get you the fitting you need...
B.
TRB on Sun May 18, 2008 6:15 PM User is offlineView users profile
Click next a few times. Should be the 4th page.
http://www.ackits.com/merchant.mvc?Screen=CTGY&Store_Code=01&Category_Code=Fittings
