Replacing Thermistor & Trinary Switch
tomibriggs on Thu May 08, 2008 2:52 AM User is offline
Year: 1996
Make: Toyota
Model: Corolla
Engine Size: 1.8
Refrigerant Type: 134
Does replacing the Thermistor on the evaporator or the Trinary Switch require evacuation of the system? Is the A/C amplifier the same as a relay?
Edited: Thu May 08, 2008 at 5:14 PM by tomibriggs
TRB on Thu May 08, 2008 9:26 PM User is offlineView users profile
I'm saying yes.
tomibriggs on Thu May 08, 2008 10:14 PM User is offline
Thank you for your response. Just to clarify, is that a YES to both questions?
TRB on Thu May 08, 2008 10:23 PM User is offlineView users profile
I'm not 100 percent sure on that one. But I believe the system will need to be reclaimed when using that switch. I checked and I don't have one in stock to check to be sure.
tomibriggs on Fri May 09, 2008 12:27 AM User is offline
Thanks again.
Is the A/C Amplifier on the illustration the same as a relay?
mk378 on Fri May 09, 2008 10:29 AM User is offline
There's no valve under the switch like most American cars have. The refrigerant must be out before unscrewing it. Looks like the evaporator case has to be taken out of the car to reach the thermistor. That would also require reclaiming the refrigerant before disconnecting the lines.
The A/C Amplifier is a little computer that looks at readings from the thermistor and other stuff to control the A/C. I think the amplifier drives seperate relays mounted under the hood.
