blend door
nextlevel on Tue May 06, 2008 8:05 PM User is offlineView users profile
Year: 1995
Make: chevy
Model: 3/4 truck
Engine Size: 6.5l
On my 1995 chevy truck the blend door is doing a strange thing. At first it would only direct air to the floor. I took out the actuator and found it had a broken gear. I replaced it with a new one. The vent still does not direct the air properly. It mostly goes into the floor. Is this a control problem?
Also, when I turn on the a/c the actuator rotates a little more toward the floor.
James
JACK ADAMS on Wed May 07, 2008 11:31 AM User is offline
Make sure that the door is in the correct position and adjust the motor prior to installing it, by plugging it in and moving the controls to mate with the door. Hope this helps and good luck.
