Mercedes w123 1984 300TD r134a capacity?
torkq on Tue May 06, 2008 4:28 PM User is offline
Year: 1984
Make: Mercedes
Model: 300TD
Engine Size: 3.0
Refrigerant Type: r134a
Ambient Temp: ?
Is there a site that might provide a capacity for older vehicles?
1984 Mercedes 300TD? using r134a?
I searched the site and came up with nothing
THANKS!
TRB on Tue May 06, 2008 5:54 PM User is offlineView users profile
I doubt you will ever find a website showing conversion capacities considering this was an R12 designed system. If you do please let us know!
torkq on Tue May 06, 2008 5:59 PM User is offline
Well, I've been told that with r12, the system should be at 2.6lbs, should it be the same with r134a, more or less?
bohica2xo on Wed May 07, 2008 3:45 AM User is offline
Actually that vehicle does not convert well to 134a. It would be a good idea to charge it with R12.
You should have a sticker under the hood that shows the refrigerant charge. Which compressor do you have?
B.
torkq on Wed May 07, 2008 4:46 AM User is offline
R4 GM
wrench on Sun May 11, 2008 8:59 PM User is offline
I had a 1984 300D that I rebuild the AC system & load with 134A & had it down to 50 @ 85. I replace the condensor with a parallele type, & use field replacable hose & fitting from areoquip(E-Z clip). Work good.
wrench
diesel is music, music is noise!
