1992 honda accord
wirenet on Mon April 21, 2008 7:15 PM User is offline
Year: 1992
Make: Honda
Model: DX
Engine Size: 2.2
Refrigerant Type: R134A
Gentlemen: I made the conversion from R12 to R134a , the old pressure switch cuts off the compressor below 38psi will I need to change to a pressure switch that cuts off at 28 psi. Also will using an air hose to blow out flush cause a moisture problem, or she I pull a vacuum a lot longer along with changing the dryer. Thank you.
Chick on Mon April 21, 2008 8:19 PM User is offlineView users profile
The flush would be more of a problem, blow all the flush out good, then do it again..Then a good long vacuum and new drier should be fine.. I've never changed the pressure switch on those, the hotter it is, the less likely it will shut down..Just my opinion.....
