pulling a vacuum
chillin on Sat April 19, 2008 2:45 PM User is offlineView users profile
Year: all
Make:
Ambient Temp: 80
When adding dye to a system that probably has a leak is it necessary to pull a 30 minute vacuum before charging to system capacity? thanks for any replies
TRB on Sat April 19, 2008 3:02 PM User is offlineView users profile
Not really, just do a quick pull down to get the air out. 2 minutes should be plenty enough time. If you plan on running the system for a few days checking for leaks. I would do a 30 minute pull down.
Edited: Sat April 19, 2008 at 3:03 PM by TRB
brickmason on Sat April 19, 2008 11:25 PM User is offline
I like to add dye to any system which does not already have it. Makes it easier to detect any future leaks.
Just another brick in the wall
Had a little mule I fed him castor oil and every time he jumped the fence he fertilized the soil
y2k600f4 on Thu April 24, 2008 9:56 AM User is offline
That is what I plan on doing...for future leak detection if needed. Wondering if I can use (1) can of R134a w/leak detection, is that enough dye ? Or do I need to use all 3-4 cans or just use the liquid dye ?
mk378 on Thu April 24, 2008 10:32 AM User is offline
One R-134a + UV dye can will be plenty. Be sure to charge with the dye can upside down, if you remove it as gas the dye will just stay in the bottom of the can.
Edited: Thu April 24, 2008 at 10:32 AM by mk378
