A6 compressor o-rings or sealing washers ? (pics)
y2k600f4 on Thu April 17, 2008 9:44 PM User is offline
Ordered the CP3011 o-ring kit and the CP3016 GM sealing washer assortment to replace all the system's o-rings and sealing washers. I just removed the compressor to flush and refill with oil. According to the GM A6 exploded view (see first pic; item #2 and #3) view it "looks" like I just need the proper o-rings ?? Currently there seems to be a black hard rubber washer (do they get removed and replaced with o-rings ?????) that is flush with the mounting surface (see second pic). Also I am guessing I need an o-ring (#22) for the sump drain plug (was none) shown in the last pic. Thanks.
mhamilton on Thu April 17, 2008 9:48 PM User is offlineView users profile
Orings in the rear ports, those black ones in the picture are just old flat orings.
The oil drain uses a crush washer (copper I believe). Not sure about where to get that.
TRB on Thu April 17, 2008 9:58 PM User is offlineView users profile
Put a little Nylog on the bolt and you will be fine. Should be some thinker # 12 o-rings in that kit. Those go in the back of the compressor. Nylog on those also.
y2k600f4 on Thu April 17, 2008 10:34 PM User is offline
Thanks yet again guys !! I suspect I only needed the washer kit for an R6 compressor ? Oh well, good to have in stock for future projects. I was guessing the bolt was self sealing but was not sure since the exploded diagram says "neoprene oil tube o-ring"; I'll just skip that one as per your advice !! Thanks and off to the compressor install.
TRB on Thu April 17, 2008 10:40 PM User is offlineView users profile
Number 2 & 3 are you o-rings. If the hoses do not sit flat against the new o-rings then you need sealing washers. I'm thinking some of the newer A6's use the sealing washer kit.
