Unfindable leak
guntherx on Mon April 14, 2008 11:50 AM User is offline
Year: 1999
Make: chry
Model: t&c
Engine Size: 3.8
Refrigerant Type: 134
i have been trying to locate a leak on a 99 town 7 country. i was using a cps leak detector before it crapped out and switched to pressurizing it with nitrogen and using an utrasonic. i cannot find a leak anywhere and yet the system looses 50% of the charge within a few days. i am debating on purchasing a uv kit, but wondered how it would work trying to indetify leaks in the 2 evaportators if you cannot see in them. any ideas?
secondly, is there a component that is prone to leaking on these vehicles?
mk378 on Mon April 14, 2008 1:27 PM User is offline
Dye will sometimes make its way to the evaporator drain but only after operating the system for a while with a full charge and condensing enough water to flush it thru. A refrigerant electronic detector is better for finding evaporator leaks. Can't really blame the car that your leak detector quit.
GM Tech on Mon April 14, 2008 4:30 PM User is offline
Your vehicle is well known for front evap leaks........
