A/C Recharge
dafinsfan on Sun April 06, 2008 12:03 AM User is offlineView users profile
Year: 1991
Make: Jeep
Model: Cherokee
Engine Size: 6 Cyl
Refrigerant Type: R-134
I am trying to charge my a/c system, the compressor kicks in, but the refrigerant is not going into the system. I have tried accelerating the car a little while the hoses are on, but nothing gets in the system. I had a 94 cherooke before and it also took me several attempts before I coul charge it. Is there a specific procedure I have to follow? Thanks
mhamilton on Sun April 06, 2008 10:47 AM User is offlineView users profile
What are the pressure readings before/after the compressor engages?
I'm guessing with a '91 and R134 that it was retrofit... could be simply bad conversion fittings not depressing the old schrader valves.
mk378 on Sun April 06, 2008 3:09 PM User is offline
Many of the older Jeeps had isolation valves on the compressor. If you have those you have to take the valve stem cap off and turn the valve stem partway (clockwise I think) to open the service port.
Measure both high and low side pressures before charging anything.
A 1991 will have a R12 system. If it has not been properly converted yet do not just put R134a in on top of the R12.
